Help! Help!! Help!!! Please!!!!
Old Mar 26, 2010 | 06:27 PM
  #21
canadian dakota's Avatar
canadian dakota
gotta code P0562 learnt that if you cycle the key to on off three time gives you a code
Old Mar 26, 2010 | 07:17 PM
  #23
canadian dakota
second opinion from midas is the same code evr say battery is low should be replaced so ima start with that and hope it solves the problem ill keep an update
Old Mar 27, 2010 | 12:27 PM
  #24
canadian dakota
well new battery put in today my cold crank amps where low 444 and the voltage was 13.26 so hopefully this solved the problem thanks for everyones help and input
Old Mar 27, 2010 | 12:55 PM
  #25
Cuban11182's Avatar
Cuban11182
Glad to hear everything worked out.
Old Mar 27, 2010 | 07:38 PM
  #27
canadian dakota
Originally Posted by ericemery
Your 08 had a dead battery already?
I think I would still look into a draw. just in case the battery was a secondary issue and not the cause.
im kinda thinking the same thing to. but figure start with the easiest replacement the truick does have 80k km plus the extra lights ive put in and constantly forgetting to turn of the cb off since i put it in last spring i can see that draining it im gonna keep an eye on it. she hasnt failed me yet today if anyone knows a quick test i can try i would like to know
Old Mar 27, 2010 | 09:19 PM
  #29
canadian dakota
well I know in the ten minutes that it took to get gas and go in and pay lastnight I left my lights on it was dead today no problems or struggles in starting
