I was a little concerned about the controller at first, but it hasnt caused any issues yet. the install was easy, and it has the option to hook up AC if you want to.
Eliminates the stock clutch fan that is crank/rpm driven. Your stock clutch fan steals power (usually around 10-15 hp) from the engine. This is your way to get it back.
Its not a difficult mod at all. Some simple wiring, no big deal. Just make sure you get a good fan controller that doesn't have a water temp sensor that has to be stuck through the radiator fins, lol.
Such WISE words... where do you come up with this stuff???
