2.5" dual exhaust, too big?
they have a SI/DO magnaflow muffler on amazon and with the said discount of 30% from this site, it will be like 70 bucks.
my question is will the dual 2.5" out be too big to run 2.5" piping all the way out the back, will i loose to much back pressure?
should i just get the muffler and have the shop use 2.25" pipe? either size pipe will not be mandrel bent so that will have some restriction
You will be fine, I would get rid of the stock y pipe. Here is a clip of my exhaust.
http://www.youtube.com/watch?v=eTmNzBD7u2I
I'm running 2.5" flowmasters on my '08 SLT and its runs and sounds fantastic. It is the complete setup including the muffler, extension pipes (running duel rear exhaust) and cat-back.
Trending Topics
I did a cat-back earlier this year which has the 2.5 dual outs. The truck is basically stock except for a SC tuner. I could never peel out going straight from a dead stop, but I could get the tires smoking if I stood on the brake with the stock exhaust. After I put on the cat-back, I lost enough back pressure to the point where I can barely get them to spin when I stand on the brake much less smoke now. But, when I get it on the freeway it will go like a bat outta hell.
