Un answered questions
Old May 28, 2010 | 11:47 AM
  #21
hendrixx324's Avatar
hendrixx324
Hey blown how much did getting the supercharger to work cost you if you dont mind me askin
Old May 28, 2010 | 11:52 AM
  #22
one last question about this.. i know there is a ton of posts on here about these but I'm too lazy to search for the exact answer...lol....if you set your truck to maximum performance or whatever, do you then have to run premium fuel? i.e. in order to get the hp/torque gains they promote, do you have to run the premium (expensive) gas?
Old May 28, 2010 | 11:55 AM
  #23
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Yeah its not only for the performance but they advance the timing so such that you need it to avoid spark knock
  #24
hendrixx324
for the SC you hve 2 performance options 87 octane and 91 octane
Old May 28, 2010 | 03:52 PM
  #25
Blown287's Avatar
Blown287
Originally Posted by jkeaton
What about firming up the transmission? Longer times between shifts, firmer shifts, etc. tow/haul gives a little longer times between shifts, but does nothing for firming up the shifts....
If you want rock solid shifts? You need the Sharadon Performance Tranny Valve Body.
http://www.sharadon.com/sdtestparts.htm
Old May 28, 2010 | 03:54 PM
  #26
Blown287's Avatar
Blown287
I spent $1,500.00 on mine and it was used. They are out there but you have to find them. Now we know the 4.6L adapter plates will work with Cobra superchargers that has opened an entirely new can of worms.
Old May 28, 2010 | 07:51 PM
  #27
hendrixx324
a cheaper can of worms? lol
Old May 29, 2010 | 03:00 AM
  #28
Raptor7's Avatar
Raptor7
wow i ask a simple ? and all this great info comes flowing out of air. so hey blown what company would you recommend to get a few of those items you mentioned on the first page? i was mentioning the idea of changing out my gears but don't know if i should or not. i do have the tow package on mine and don't know if its worth it or not.
Old May 29, 2010 | 06:00 PM
  #29
canadian dakota's Avatar
canadian dakota
while we,re having an ask blown sestion here lol how much work and cost was the 4:10 gearing
Old May 29, 2010 | 10:19 PM
  #30
Blown287's Avatar
Blown287
We will start with Camshaft. You have the option of HO, 206, 212, 212x and 224 grind cams.
http://www.krcperformance.com/
http://www.airram.com/product.php?ca...productid=1308
You have several gears setups to choose from also. The trouble with 4x4 is finding a set for the front. For gears you have 3.55, 3.92, 4.10, 4.56 etc.
http://moesperformance.com/index.php...dex&cPath=2_36
If you want to run boost look into sts turbo sytems.
http://www.ststurbo.com/what_s_included
Also any supercharger designed for the SVT Cobra 4.6L will work thanks to Airrams mounting bracket. You will have to have custom pulleys made to get the belts to line up.
http://www.airram.com/product.php?ca...productid=1297
Bigger Injectors
Bosch 0280156127 #39 Injectors designed for the SVT Cobra. They are a direct replacement.
http://www.mcnewsautomotive.com/Prod...ductid=MA1052D
For Exhaust you have high flow cats
http://www.spintechmufflers.com/cata...s/cat_124.html
Performance mufflers
http://www.borla.com/products/universal.aspx
Headers
Gibson
http://www.autopartswarehouse.com/de...QG27GP316.html
JBA
http://products.jbaheaders.com/detai...p?id=1949S-2JT
Tuners
SCT
http://www.sctflash.com/
This should get you started.
