rear diff vibration issues
Old Jun 11, 2010 | 07:57 AM
'06RedDak's Avatar
'06RedDak
Default rear diff vibration issues
Ok, I am overdue on changing my rear diff fluid (truck has 47K miles), so I don't need hammering on that. It is Dodge's anti-spin rear diff. I get a vibration when turning corners from a stop. Feels like it's slipping, but not sure if that's really what's going on. About six weeks ago, the fluid was checked by the technician. Full, no leaks, and no metal shavings. It wouldn't act up for them, either.
It's definitely vibrating now, only in the turns.
To prepare me for the worst, could I have a bad gear of some type (I would think there would be metal shavings in the fluid), would the clutch plates need replaced, or do I just need to change my fluid.
I have scheduled to have the rear diff fluid changed. The shop is pretty good, they have always fixed any problems I've had in the past. More than what the dealer ever did and for a lot less.
By the way, should I request a certain type of fluid (with an additive)?
I am new to this thread and this is my first posting. Thanks in advance.
JD
Old Jun 11, 2010 | 10:21 AM
JimBio's Avatar
JimBio
Your fluid is no longer working, once it's changed the problems should clear up. If the friction modifier is not working it will cause the limited slip to kick in under turns and feels like it's jerking or rubbing and once you get straight it's stops. It feels the same if you use just straight gear oil and no FM. Change the fluid often (20-30K) and the bearings and clutch pack will last a long time, go another 47K and you might be replacing some broken parts.
Old Jun 11, 2010 | 10:35 AM
canadian dakota's Avatar
canadian dakota
my suggestion royal purple though it is costly but worth it I plan to change all my fluids to that purple goo lol
Old Jun 11, 2010 | 10:40 AM
herkguy's Avatar
herkguy
JimBio hit it, make sure you add the special FM when you change it, its just a small bottle available at the dealer.
Old Jun 11, 2010 | 03:15 PM
'06RedDak's Avatar
'06RedDak
Hey guys, thanks for responding. You've been the best help yet. If there is anything broken, what are the possiblities? Also, after the fluid change, will it take a some driving before things totally clear up? Thanks again.
JD
Old Jun 11, 2010 | 06:37 PM
sdsdsd's Avatar
sdsdsd
no FM needed with royal purple, it's in it.
Old Jun 12, 2010 | 09:39 PM
JimBio's Avatar
JimBio
Common failure with worn out fluid is bearings going out. On my previous truck I went to long on the first change and it started to make a humming noise when I turned. Changed the fluid and it went away, well a short time later I had gears installed. They told me one of my bearings wore out and welded itself together practically, they had to pound it out.
Old Jun 15, 2010 | 07:44 AM
'06RedDak's Avatar
'06RedDak
Got the rear diff serviced yesterday, boy she's like new. Nice, smooth, quiet, unoticable. Just the way it should be. Just in time to pull the camper this weekend.
Old Jun 15, 2010 | 07:09 PM
Altair's Avatar
Altair
Dak attack!
Glad to hear it, don't forget to write down your mileage so you can change it under 30k next time.
Old Jun 15, 2010 | 07:25 PM
sullysdetailing's Avatar
sullysdetailing
I would recomend AMSoil it out preforms all other ATF and rear diff fluid
