superchips trans download question
Old Jun 17, 2010 | 12:57 PM
coondog05's Avatar
coondog05
Default superchips trans download question
when i plug in my tuner and it does its upgrade thing, it says its up to date.... but when i look for the trans update it isnt there? the only thing that comes up is the data upgrade and the tuner unlock one.... i went to both vehicle 01 and 02 and they both are blank. my tuner is locked to my vehicle and everything seems to be accurate..... any help would be great....thanks
Old Jun 17, 2010 | 01:33 PM
dodgetrucker75's Avatar
dodgetrucker75
did you download it back during the free trial? if not you have to pay for it now, $40 i think
Old Jun 17, 2010 | 02:26 PM
rengnath's Avatar
rengnath
Sometimes the updater doesnt automatically "update" itself. Your best bet is to uninstall the program from your computer, and download the newest version off of superchips.com. Try that and let us know if it works. Otherwise you'll have to call their tech support.
Old Jun 17, 2010 | 02:54 PM
dakotaff's Avatar
dakotaff
It's funny how it was not available for me until they started charging $40. Bastards!!!!!!!!
Old Jun 17, 2010 | 03:01 PM
rengnath's Avatar
rengnath
It is totally worth the $40 though. I would honestly recommend the tuner just for the transmission tuning. Itll make your truck a blast to drive.
Old Jun 18, 2010 | 02:02 PM
rengnath, what exactly will it do to the trans?
Old Jun 18, 2010 | 02:54 PM
rengnath's Avatar
rengnath
If you reduce torque managment, it will shift firmer.
If you do a custom schedule, you can make it shift at any point at any throttle position. For example, while cruising at a set speed with a stock shift schedule, in order for the truck to downshift you will have to give it x% of throttle. If the requiered TP% in order to downshift is high, this wastes gas and makes the truck less responsive.
In a custom schedule, you can make the downshifts happen with giving less throttle therefore saving fuel and being much more responsive when you hit the gas. In all honesty, this is as close to a manual transmission as you can get if you have an automatic. You can make the tranny shift at any time and its all custom, so you make it to your preferences. It takes a lot of time, but now that I have the transmission tune I have a hard time not driving with a smile on my face.
You can also make it hold in a gear longer than normal, or shift up sooner. And it is all determined by the TP%.
Old Jun 19, 2010 | 09:05 AM
thats the 3865 correct?
Old Jun 19, 2010 | 09:53 AM
rengnath's Avatar
rengnath
3865 or 3950. Then the trans option is an additional $39.95 per vehical.
Old Jun 19, 2010 | 10:07 AM
coondog05's Avatar
coondog05
i called and they said if it doesnt show up that my truck isnt supported yet? he said there is a bunch of different programs written for the same years of trucks, so i have to just wait? sounds like bs but i guess im stuck.....
