160 degree t-stat
Old Jul 14, 2010 | 11:38 AM
sleds's Avatar
sleds
Default 160 degree t-stat
Has anyone tried a Mopar 160* thermostat, or is this too cool for our trucks?
Old Jul 14, 2010 | 12:51 PM
95_318SLT's Avatar
95_318SLT
160 is too cool for electronic fuel injection. The coolant has to reach a certain temperature before the computer will switch into closed loop. It would basically be like you're running the choke on a carb the entire time you're driving if the computer can't switch to closed loop. I think the temp for the switch is around 180, cause I have a 180 in my truck and it throws the open loop code sometimes in the winter.
Old Jul 14, 2010 | 12:54 PM
popsnbeer's Avatar
popsnbeer
Wouldn't that put unecessary added strain on your cooling system (fluid, water pump, fan, etc.).
Old Jul 14, 2010 | 01:27 PM
dakotajerry's Avatar
dakotajerry
This is true but just because it has a 160 doesn't mean it will run at 160. I had a 160 stat on my last truck but the truck always ran between 178-185. The stock 180 ran around 190-195. Also running the 160 will lower your mpg. keep the stock stat.
Old Jul 14, 2010 | 03:01 PM
sleds's Avatar
sleds
o.k. Thanks guys, I was just wondering how cool we could run our engines. But I do know too cool is not any good for an engine.
Old Jul 14, 2010 | 10:31 PM
Blown287's Avatar
Blown287
A 160 will just open a little sooner you will still probably run around 180 average temp or so.
Old Jul 15, 2010 | 02:31 AM
hendrixx324's Avatar
hendrixx324
for chevys a 160 degree is like our 180 degree.
