new mags wheels???
Old 07-19-2010, 07:36 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
Default new mags wheels???
im about to buy new mags because stock one gives me vibration at braking when i use wheel spacers. im using 2x 0.5'' one over the other in front with very minor rub.
so ultrawheels like blown's one exept i dont like drifters probabely gonna go for nomads or maverick black 16X8 +10 offset what you prefer?
and blown what you think about your mags quality? do they center properly do they need centering ring?
http://www.ultrawheel.com/wheel_brand.cfm?brand=1
Old 07-19-2010, 10:44 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
plz advice?
Old 07-21-2010, 01:01 AM
sleds's Avatar
sleds
sleds is offline
I personally like a simple wheel. Alot easier to keep clean, so I like the Nomads. But either one will work. Do they make a 0 offset? That is what Trucker is using with his 33x12.5's with no rub. I'm just wondering with the +10 offset if you are going to get a bit of frame rub. If you are running 1" of spacers on the front then you have 0 offset right now. +25mm offset stock wheel with 1" spacer = 0 offset.
Old 07-21-2010, 01:28 AM
dodgetrucker75's Avatar
dodgetrucker75
dodgetrucker75 is offline
yep, i run a 0 offset, but that is with a 9'' wide wheel and 12.5'' wide m/t's, the tires get very VERY close to the frame at full lock but no rub, so i have them pulled in as far as they can be with out frame rub and best fender clearence, but IIRC you are running 285's so you may be able to get away with a little offset but it will be close
Old 07-21-2010, 07:21 AM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
Default thanks
from what i have learn with the conversion chart backspacing of
16x8 with +10 offset is almost the same offset as a 18X9 0 offset
and maybe 16x8 +10 will stick out more because +12 would be perfectly egal (5 inches of wheel backspacing) so the nomads should have around 4.80 of wheel back spacing refer to this chart
https://www.rsracing.com/tech-wheel.html
0 offset on a 8'' wide wheel should wave 4,5'' of back spacing wich would cause rub on fenders??? am i right?
Old 07-21-2010, 07:47 AM
WTEBOY703's Avatar
WTEBOY703
WTEBOY703 is offline
my dick cepek 16X8 have a 12mm offset and i dont feel anyvibrations or anything! now granted i had to trim down the mudflaps but that was too easy and i love the rims!
Old 07-21-2010, 05:33 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
http://www.dickcepek.com/wheels.php?item=DC2Black
excuse me they are -12 with my tire they gonna rub like crazy to body
i think dodge trucker75 tried them with 375 75 16 on mickek thompson with major rub am i right?
Old 07-21-2010, 05:36 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
in so afraid to waste money they are not refundable after they are mounted :S
16x8 +10offset
or 16X8 0offset
i dont want to change my tires for 18 x9!!!
Old 07-21-2010, 06:16 PM
dodgetrucker75
i would say go with the 0... atleast you know you will have frame clearence, and worst case, you may have to trim some plastic but i dont think you will
Old 07-21-2010, 07:21 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
Default thanks
but what was the mag size you had major rub problem?
my plastics are already majorly modified. im affraid of countact with body of the front fenders .
Quick Reply: new mags wheels???
