error P0440 with engine light on
Old Jul 23, 2010 | 09:02 PM
Ramulator's Avatar
Ramulator
Default error P0440 with engine light on
Hi , was woundering if someone knowleggable could answer this question... my engine light is on and i get error code P0440 ...does anyone know what this means ?
Old Jul 23, 2010 | 09:45 PM
rengnath's Avatar
rengnath
P0440-GENERAL EVAP SYSTEM FAILURE
Thats for a Dakota though. Not sure if you are looking at a code on your Ram, or if you have a Dak.
Old Jul 23, 2010 | 10:17 PM
Ramulator's Avatar
Ramulator
Thanks ... its on my 2003 ram 1500 4.7 . So now i'm wounder what that could mean ???
Old Jul 23, 2010 | 10:29 PM
rengnath's Avatar
rengnath
I believe it could be something as simple as a bad gas cap. Im not too sure though on how to diagnose an EVAP problem.
Old Jul 23, 2010 | 10:39 PM
jake7's Avatar
jake7
Check your lines running to tank etc. Check your charcoal canister and the gas cap. Sometimes if it's loose it will throw a code.
Old Jul 23, 2010 | 10:40 PM
Blown287's Avatar
Blown287
Usually a failure in the gas tank seal. Check your gas cap first off.
Here you go.
http://www.obd-codes.com/p0440
Old Jul 24, 2010 | 09:38 AM
canadian dakota's Avatar
canadian dakota
I've had that code pop up as well as some other evap codes plus my odometer keeps telling me my has cap is loose. truck is still running fine I think it may just be a bad sensor haven't really looked to closely. but I have checked all my lines to the gas tank and haven't found anything
Old Jul 24, 2010 | 01:10 PM
Ramulator's Avatar
Ramulator
I know the A/C is not working at all ... could that be the cause of a vacum leak error if it had a leak?
