Need boosting help
Old 08-04-2010, 07:06 PM
ruger226's Avatar
ruger226
ruger226 is offline
Default Need boosting help
Well im planing on a rear mount turbo from sts and need to know what else to buy.
1.sts universal turbo kit
2.Headers and cats
3.sct tune
4.Maby 224 cams
5.boost and a/f gauges
6.Injectors
If i need anyting else please help
Old 08-04-2010, 07:38 PM
Blown287's Avatar
Blown287
Blown287 is offline
Solid motor/tranny mounts, 2-BAR MAP. Ensure the kit comes with a BOV, if not you will need to buy one.
If you go with the 224 grind get the grind Travis has. Mine is a Turbo grind, his is super lopy and I love the way it sounds!
Old 08-04-2010, 07:48 PM
ruger226's Avatar
ruger226
ruger226 is offline
Yea i think it does come with a bov and if not i can get one for free. And what does the 2 bar map do?
Old 08-04-2010, 08:07 PM
Blown287's Avatar
Blown287
Blown287 is offline
BAR is a unit of pressure. At sea level you are feeling the effects of 14.7 psi, sometimes referred to as one atmosphere, sometimes referred to as 1 bar.
MAP is Manifold Absolute Pressure
Superchargers compress air and pressurize the Manifold. Your tuner needs a sensor that can sense and monitor the pressure. Your PCM calculates the air density to determine air mass flow ratios to control fuel injection to maximize power.
Old 08-04-2010, 08:22 PM
trucky's Avatar
trucky
trucky is offline
The kit comes with 2bar sensor and an SCT tuner already.
Old 08-04-2010, 08:35 PM
ruger226's Avatar
ruger226
ruger226 is offline
It dosent say that it comes with the tuner or a map sensor but i will call tomorrow
Old 08-04-2010, 08:36 PM
Blown287's Avatar
Blown287
Blown287 is offline
LMAO
Old 08-04-2010, 09:10 PM
ruger226's Avatar
ruger226
ruger226 is offline
Actually truckey i belive you hahaha.
Old 08-04-2010, 09:12 PM
Blown287's Avatar
Blown287
Blown287 is offline
Actually both Trucky and I are tuned by Mr. Sean Powell, an SCT field tuner for Watson Performance. His email is hemifever@aol.com and he offers tuning deals with the tuners.
Old 08-04-2010, 09:13 PM
trucky's Avatar
trucky
trucky is offline
Oh yeah injectors come with it already too...
This top seller single turbo kit includes a 67mm turbo, injectors, map sensor, SCT, Blow off kit, wastegate, K&N Filter, scavenge pump, and lines, clamps, couplers, and pipe.
you don't need anything else that's what makes it a kit. Blown is right about torque dampers though our engine mounts can't handle the extra power.
Quick Reply: Need boosting help
