Alarm/remote starter
Old Aug 24, 2010 | 10:38 AM
  #22
dingdong2's Avatar
dingdong2
Ok well I think ill buy a viper remote start/alarm system. I'm more interested in the alarm anyways.
How does Viper do standard transmissions? Do I need a specific model or do all models work w/ an addon module?
Originally Posted by ericemery
they are still a pita, you might get away without needing bypasses, but more than likely will still need resistors and relays. The parking lights need resistors, and I don't remember if we have a second starter wire that needs hooked up...
Old Aug 24, 2010 | 11:10 AM
  #23
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Just putting this out there.
On the stock starter systems, it will shut off when one of these occur:
• If the doors are left open for 60 seconds or more without the key being inserted in the ignition
• If the engine stalls or RPM exceeds 2500
• Any engine warning lamps come on
• The hood is opened
• The hazard switch is pressed
• The transmission is moved out of park without the key being inserted in the ignition
• The brake pedal is pressed.
Old Aug 24, 2010 | 12:42 PM
  #25
dingdong2's Avatar
dingdong2
Default clutch signal kit?
Does Viper sell a kit for that? I don't want to have to rig anything, I want to buy the parts that support a standard transmission.
You will need to build a clutch signal relay. it will tell the truck and starter that the clutch is pressed when it attempts to start the truck.
Old Aug 27, 2010 | 03:45 PM
  #27
BrandNew's Avatar
BrandNew
you have 2 wires that go to the clutch pedal that you can twist together to by pass that
Old Aug 27, 2010 | 06:18 PM
  #29
dakota_raven's Avatar
dakota_raven
This are the specs for the Viper 5901 Responder LC3 alarm that ericemery has on his truck.
Check the highlighted text... here is the link to it!!! Hope it helps. Good luck!!!!
http://www.sonicelectronix.com/item_...-n+5702V-.html
The Viper 5901 Responder LC3 is a complete security and remote start system with a full one mile range. The remote has easy to understand priority icons and a text screen on a LCD display. This allows you to command and monitor the vehicle with simple and prioritized buttons. The five buttons control up to 24 different functions on two cars! Plus, it is the slimmest display remote on the market today but still packed with the latest features.
Not only is this a security system but it also has remote start capabilities. If the Active Temp Check is selected, the Responder will display the temperature inside of the vehicle instead of the time. This comes in handy as it lets you view the temperature before actually walking to your car. Not cool, or warm enough in your car yet? Use the Runtime reset to extend your runtime and let it reach the perfect conditions. If anything happens to your vehicle, the security system will notify you right away if you are within range, playing the Revenger siren tones.
Product Features:
  • SST LCD remote transmitter
  • One mile range
  • Priority icons for simple and clear vehicle monitoring
  • Clear text labels on the large LCD screen
  • The important icon will display 3x larger than the less critical icons
  • Priority User Interface controls 24 functions with 5 buttons
  • Dual car support
  • Active Temp Check will display the current temperature inside of your vehicle (Displays in either Fahrenheit or Celsius)
  • Runtime Reset will extend your remote start run time
  • The 2-way transmitter will communicate by way of an audible tone, a vibration, or a visual alert
  • In case of an alert, the Revenger siren will play from the transmitter
  • SilentMode2 will send the alerts to the transmitter only and not set off the cars siren
  • The 2-way pager will notify whenever there is any activity with the vehicle, so you know exactly what is going on
  • Each mode is displayed on the LCD screen to remove any doubt of which mode you are in (for example: "Valet Mode" will appear when the car is set to valet mode)
Product Convenience Features:
  • XpressPort™ can dock the Innovations Award-winning CANMAX400DEI databus interface into the Responder LC3 CPU, for a direct digital connection to *******ly every new vehicle and databus architecture on the planet
  • D2D Serial Data Port gives installers plug-and-play connection to all the other XPRESSKIT interfaces
  • ******* Tach means no tachometer wire connection required
  • Flex Relays Onboard for remote start and light flash eliminates the need for additional relays the majority of the time
  • Control Center combines the Status LED and Valet Switch with the 2-way Antenna, making the switch easy to locate, and eliminating drilling of any holes in the dash
  • Priority User Interface includes SmartStart, Timer Start, Runtime Reset, TempCheck and Silent Mode2 siren-less arming modes
  • Compatible with manual transmissions
  • SuperCode encryption
  • Domelight supervision
  • Stinger DoubleGuard shock sensor
  • Neo Revenger 6-tone siren
  • Failsafe starter kill
  • Anti-Carjacking (VRS)
  • Guaranteed protection plan (GPP)
  • 4 Auxiliary channels for optional functions
  • Remote Control trunk pop
  • Compatible with Viper SmartStart Module (VSM100)
  • 1-year SonicElectronix.com warranty
Old Aug 27, 2010 | 06:37 PM
  #30
jose13b's Avatar
jose13b
hey if you need a wire diagram for you truck to do a remote start or alarm I can fax you one just give me the year make and model I use the autopage 900 pager alarm look up www.autopageusa.com
File Type: jpg
