New tires for my 2010?
Old Aug 25, 2010 | 11:16 PM
victorjg's Avatar
victorjg
Default New tires for my 2010?
Hi:
I own a 2010 Bighorn Crewcab, it comes with 265/65/17.
May I install 265/70/17? Front tires will rub at the rear part of the fender, to be exactly in the splash guards? Or not?
Thanks
Victor
Old Aug 25, 2010 | 11:34 PM
Blown287's Avatar
Blown287
https://dodgeforum.com/forum/3rd-gen...5-75-16-a.html
Old Aug 26, 2010 | 03:16 AM
WTEBOY703's Avatar
WTEBOY703
yeap what he said!
Old Aug 26, 2010 | 07:13 AM
victorjg's Avatar
victorjg
Hi:
Thanks for the advice, but I'm running 17'' rims not 16'' like the thread is about.
Victor
Old Aug 26, 2010 | 08:11 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Here this site maybe able to help ya out as well... http://www.1010tires.com/tiresizecalculator.asp
With the calculator you can almost match sizes for different rims
Old Aug 26, 2010 | 02:58 PM
mprohr's Avatar
mprohr
I have that exact size tire on mine LT265-70-17 on stock wheels. You will need to trim about 1.5 inches of plastic off of the inside of the splash guard. I recommend using a hot-knife. That is the only place it rubs, and is an easy fix.
Old Aug 27, 2010 | 04:56 PM
victorjg's Avatar
victorjg
Hi:
Ok, great 265/70r17,my splash guards are painted of the color of my truck, white, if I trim it I think is going to see horrible!.
Do you have pics of you job, just to have an idea and see how looks your truck with those tires.
Thanks
victor
Old Aug 27, 2010 | 06:39 PM
dakota_raven's Avatar
dakota_raven
Originally Posted by victorjg
Hi:
Thanks
victor
Victor, don't worry! get the duplicolor paint to match yours and when you are done trimming paint it. No one will notice it
Old Aug 27, 2010 | 11:23 PM
mprohr's Avatar
mprohr
You won't even need to paint it. If you are patient, and have a really hot knife, you can cut a factory clean edge. I recommend using a sharpie marker to scribe the cut first. You can still drive it home from the tire shop. You will see (and hear) exactly where it is rubbing. You are cutting away a small amount of plastic that is inside the fender wells. You'll never notice a difference. I'll try to take a photo in the AM.
