Old Aug 6, 2015, 12:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Interior (dome) Light Wiring
Old Sep 8, 2010 | 10:49 PM
Talking Interior (dome) Light Wiring
I want to add some LED interior lighting under the dash, where is the most convenient place to tie into the dome light circuit? I have the wiring diagrams, but it shows no fuse dedicated to that circuit, so I need to find the wires, i.e where they come from under the dash. Just wondering if anyone has done this and where did you find the power wire for the dome lights under the dash.
Old Sep 8, 2010 | 11:17 PM
Hammond_Egger's Avatar
Hammond_Egger
Check page 2254 of the service manual. Also, I know the wires are present on the passenger side pillar post..
Old Sep 8, 2010 | 11:23 PM
donkeypunch's Avatar
donkeypunch
King Jackass
We need some more clarification. Are you looking to add lighting when you activate your dome lights? Or are you looking for more interior lights when you activate your parking/exterior lighting?
Here is what I would do if you cannot find the information for a quick install.
Get a good volt meter from radio shack, lowes, etc.
Test the wires and locate the switched 12V sources. Most people like to use "vampire" style connectors. Personally, I like to cut the insulator off, solder the connections, and heat shrink.
Old Sep 8, 2010 | 11:36 PM
rengnath's Avatar
rengnath
I would be tapping off the wire up by the dome light, after the manual switch. I would wire the two seperate dome lights to the right (passanger) side switch. I would then tap the hot wire off the left (driver) side switch, and run that under the dash. Reasoning: the LED lights you add will come on when you unlock your truck, open the door, or use the dimmer switch to the left of the steering wheel to turn on the dome lights. You will also be able to manually turn on the LED lights with the overhead drivers side switch. You will loose ability to turn on each dome light seperatly, but if you need light you can turn both on with the passanger side switch. Sorry for the long explanation, but this was how I was planning on wiring up some running lights.
Old Sep 9, 2010 | 06:19 AM
graythang's Avatar
graythang
All just remember that the can-buss operates all lighting and will use the circuit draw sense or battery saver to turn off the lights if on for a period of time. To get around that you need to connect to a non can-b light circuit or to battery power direct
Old Sep 9, 2010 | 09:28 AM
Yea, I want them to come on with the dome light when either opening a door or activitaing the unlock with the remote. I know which wire it is from the diagram, I just needed to know where the wires come down to the dash from the ceiling (left or right side pillar). I was just going to tie right into the line that is hot when the door is opened.
Old Sep 9, 2010 | 05:52 PM
Hammond_Egger
Wires come down passenger side pillar, very simple to see and get to once you take off the pillar (two screws).
Old Sep 9, 2010 | 06:03 PM
smoker911's Avatar
smoker911
Hey JKeaton ,,That is what I've wanted to do. I have mine installed under the glove box and under dash on Drivers side .But don't know where the wires r .So when you find the wire can u let me know so I can finish hooking mine up OK please thanks a lot ,,,,,,,,,,,marc
Old Sep 9, 2010 | 08:17 PM
Thanks Hammond...two screws and a few feet of wire, I'm all set. New LED's under the dash that come on when the doors are opened. Very cool! They are LED's, so I don't see an issue with loading the circuit down and having to use a relay. This forum is great!
