New off road lights - one won't work!
Old Sep 13, 2010 | 05:39 PM
Odynn77's Avatar
Odynn77
Default New off road lights - one won't work!
Hey all,
I just attached a new set of Navigator 55 watt utility lights to my '05 Dakota. One light works fine and the other doesn't. I wired them using Hammer's schematic with a relay in the middle and the switch wired to the fusebox. I took apart and re-wired everything from the splice connector leading to the problem light and it still had no effect.
This is my first electrical project and I'm not sure if it's the one light or if I'm now not quite sure what to look for to find the issue. Any ideas on how to verify the problem?
Old Sep 13, 2010 | 05:44 PM
hendrixx324's Avatar
hendrixx324
use a test light and make sure you have power going to the light thats not working.
Old Sep 13, 2010 | 06:55 PM
first things first, like rengnath says, check to see if you have power going to the one that don't work and it has a good ground. Where did you mount them? also check the bulb on the one thats not lighting, swap it with the one that does work. I've had bad bulbs before right our of the box.
Old Sep 13, 2010 | 07:15 PM
Odynn77's Avatar
Odynn77
Thanks guys! Guess that's the next step. Test light and bulb check it is.
Old Sep 13, 2010 | 07:26 PM
hendrixx324
No problem man!
Old Sep 14, 2010 | 01:23 PM
HammerZ71's Avatar
HammerZ71
I always make it a point to test new lights right out of the box on the battery or my "jump box" before ever going to install them.
Test light or meter your connections, and test the light with just the pigtail by holding it to a battery. Wouldn't be the first bad solder joint or bulb out of the box.
Did you crimp connect or solder and heat shrink your connections? I tend to not use the crimp on's, easier but they often don't work worth a crap...
Old Sep 14, 2010 | 09:37 PM
I crimp and then solder the crimps....thought I was being overly ****....lol
