Alternator is dying
Old Oct 1, 2010 | 10:30 PM
  #21
Blown287's Avatar
Blown287
My only concern with the caravan alternator would be getting the belts to line up. I would pull yours out and take it to autozone and do a side by side comparison.
Old Oct 1, 2010 | 10:34 PM
  #22
Ueland's Avatar
Ueland
Originally Posted by Blown287
Stock 136 amp with 2.5" pulley
Thanks for the measurements..
I still think I'm gonna try the smaller pulley after I get the HHR fan installed.
BTW, had a question or two on that fan setup.. I'll probably be workin on it tomorrow...
Old Oct 2, 2010 | 12:37 AM
  #23
Blown287's Avatar
Blown287
No problem man. Please let us know how your install and alternator mods go.
Old Oct 2, 2010 | 10:53 AM
  #24
canadian dakota's Avatar
canadian dakota
whats a smaller pulley do
Old Oct 2, 2010 | 11:49 AM
  #25
Blown287's Avatar
Blown287
Makes more revolutions. As your engine RPM pick up so does the output of the alternator. So if you put a smaller pulley on the alternator the theory is that would be like driving at higher rpms = more output.
Old Oct 3, 2010 | 03:00 PM
  #27
canadian dakota
so it would create more amprage......????? wouldnt that burn it out quicker ??
Old Oct 3, 2010 | 04:05 PM
  #28
Six_Shooter's Avatar
Six_Shooter
No, an alternator can only make as much current as it's designed for an the components can handle.
The only drawback to a smaller pulley is that you may overspin the alternator at higher engine RPM. This can cause a couple situations, you can experience physical damage or failure, especially if you overspin it often, or you can experience a drop off in output at higher RPM, due to the magnetic field being created actually getting larger than the windings in the alternator itself. This would be pretty rare though, and is usually only experienced on "built" alternators in small housings.
Old Oct 3, 2010 | 05:50 PM
  #29
canadian dakota
ooooohhhh k i think i understand lol
blown PM sent
Old Oct 3, 2010 | 06:13 PM
  #30
Ueland's Avatar
Ueland
A smaller pulley would increase the alternator output but ONLY at lower rpm's usually under 2k.
The main failure issue would be the bearings at higher RPM's such at WOT runs.
Being that average crusing RPM is between 2200 and 3200 the alternator should be fine for normal day to day use with no ill effects.
I actaully posted a chart in the HHR fan post about alternator pulley sizes and differences... its basically just doin the math and deciding what you want to accomplish.
