Just got back from PA, no power windows now?
Old Oct 3, 2010 | 06:58 PM
Ueland's Avatar
Ueland
Originally Posted by ericemery
Has anyone had this problem? my power windows refuse to work...
I checked for blown fuses, and they are all fine. I need to figure out what relay to check. They worked fine on thursday morning, now nothing. very strange.
Did you try them individually or just from the drivers side control switches?
Old Oct 3, 2010 | 07:37 PM
Blown287's Avatar
Blown287
Is your low voltage indicator coming on? When my alternator started dying my low voltage was on and I lost the power windows, fog lamps and accessory outlets.
Old Oct 3, 2010 | 09:04 PM
brbcbrent's Avatar
brbcbrent
Not sure if this is even applicable for our trucks but I had all my power windows and sunroof crap out on my Nissan and it turned out to be a bad Body Control Module
Old Oct 4, 2010 | 05:37 AM
WTEBOY703's Avatar
WTEBOY703
yeah take out the Switch board itself and test it...cause i believe there is a fuse on the bottom of the window/door lock thing on the door if you remove the whole thing from the door!
Old Oct 4, 2010 | 08:57 AM
dakotajerry's Avatar
dakotajerry
Have you pulled the door panel recently? This happend on my wife Durango. I had changed the door speakers and i didn't plug the harness all the way in. 3 months later the power windows had stoped working. Plug it back in and everything worked.
Old Oct 4, 2010 | 04:20 PM
canadian dakota's Avatar
canadian dakota
my passanger side is intermittent it will go down and not come back up some times itll die and other times itll work i usually hafta play with the switch and itll kick in hasnt done it fir a while now
come to think about it it started after playing inthe sand dunes lasty summer
