EGR Valve Diag.
#31
Thanks Deer Hunter! I see where it is now. I was looking down by the a/c condenser, lol. No luck in finding any leaks. My last hope is a Mopar TB gasket, otherwise Eimer is going to come take a look at it and he will take the TB if we cant figure it out.
Ive been using Felpro gaskets since day 1 of my TB swap, and I recall switching back to the stock one which was a little worn once, and actually fixing the problem for a hundred miles. My thought process is Felpros gasket looks thinner than the stock one so it could be causing a small leak at times which is why I got brakleen to bog the engine down once while spraying it. If this Mopar gasket does fix my problem, my shoe may go up someones you know what at Felpro.
