Sonnax Has arrived
I ended up taking my Sonnax off ..... not to wild about how it shifted in to OD with the Superchips. It was kicking in to the high gears, not doing a crisp shift.
I think I may have to turn TM to "stock" during all shifts, and then at WOT keep it down at 10%.
Im undecided. I did have my modified TM at all throttle positions along with WOT at first. I then changed it to "superchips" for variable throttle but kept the "user" settings for WOT. With the superchips TM it did shift nicer, but I wasnt too happy today when I took off from a light and the truck wouldnt shift out of second gear. Ive never had that happen before, and I ended up having to pull over and shut the truck off. No codes though so it wasnt in LIMP.
I may take $6 for it .... jk.
If anything it can sit on the shelf next to my throttle body that may be coming off .... again. It started giving me a high idle today after I thought I fixed it. FML
Without tuning Im sure this thing does a nice job. With the TM removed though, its not making a desirable shift, IMO. The TM already makes the truck shift better, so the increased line pressure probably over does it.
