Larger tire size causes front-end shaking
Old Oct 20, 2010 | 08:56 PM
08dakotamod's Avatar
08dakotamod
Default Larger tire size causes front-end shaking
I think I @#$%ed up big time guys.
I went from 265/60/R20 tire size to a 275/70/R20 and man
as soon as I hit 50-60 mph, my whole front shakes and vibrates.
Anybody experience this? Suggestions?
Thanks in advance!
Old Oct 20, 2010 | 09:21 PM
superdak05's Avatar
superdak05
on the frt of the brake rotors, there are little brass clips that hold the rotor to the studs, remove those brass clips and your shake should go away, all of us had this issue with those little tabs, they just throw the rim out of wack just enough to cause the shake
Old Oct 20, 2010 | 10:26 PM
mprohr's Avatar
mprohr
Could be the clips.....or it could be the tires. These trucks are sensitive to oversized tires. If it's not the clips, I suggest taking it back to where they were purchased and have them re-balance the tires. If that dosent help, ask for a different tire. What kind of tires did you get? Aggressive tread does not help.
Old Oct 20, 2010 | 10:33 PM
hendrixx324's Avatar
hendrixx324
yea those big tires can be a pain to ballance. So if those clips dont work i would try getting them rebalenced
Old Oct 20, 2010 | 10:44 PM
mprohr's Avatar
mprohr
If all else fails. Order Dyna-beads from InnovativeBalancing.com.
Old Oct 20, 2010 | 11:00 PM
WTEBOY703's Avatar
WTEBOY703
hooah gotta love the dakotas handling capabilities with anything you throw on it! lol
Old Oct 20, 2010 | 11:23 PM
rengnath's Avatar
rengnath
If you think its the tire/wheel not being balanced, a guy with a H1 Hummer that banks where I work said he tried everything including golf *****, but he found the best thing to be 16oz of antifreeze inside the tire.
Old Oct 20, 2010 | 11:25 PM
hendrixx324
Iv never hurd of that. Would water work?
EDIT:never mind thatll freeze hah
Old Oct 21, 2010 | 12:53 PM
Amanka's Avatar
Amanka
i had to have mine balanced twice to get them right
Old Oct 21, 2010 | 04:22 PM
canadiandodge's Avatar
canadiandodge
mine still shake i think i gotta get new tires
