06 dakota 9.25 gear swap
Does anyone have any clue how or why when you go to a 4.56 gear ratio the axles will not go back in because of the spider gear shaft hits the ring gear when you try to take it out to install the axles. I believe the speed sensor is installed in the rear end and it seems that the gear that is built on the carrier housing is the issue. I need some major insight fast. Please help.
My understanding is you can also buy a modified cross pin or rework the pin yourself. I am considering 4.10 or 4.56 gears and just can't decide. For me with the stock 265/65/17 wheels it is a tough choice. I think 4.56 would be perfect in town but the highway RPMs seem a little high for my 30.5 inch tall tires.
Anyway, like the above posters said you can either grind a couple of teeth or modify the cross pin. Good luck and let us know how the gear swap went.
