Rough shift between Park, Neutral and Reverse...
Old Nov 9, 2010 | 12:26 AM
nate_lynch's Avatar
nate_lynch
Default Rough shift between Park, Neutral and Reverse...
I just purchased a 2007 Dakota SLT with the automatic transmission.
I have noticed that when shifting from Park into neutral that there is a bit of a bang and the truck jerks a bit. It sounds worse than it is. It's really not too bad but it happens almost every time I put the truck in neutral from both park and drive and I don't think it's normal. I haven't noticed any other shifting problems though.
Anyone else have this problem or know what might be causing it?
Old Nov 9, 2010 | 01:26 AM
SilverGhost1's Avatar
SilverGhost1
mine has been doing it since it was new. no worries.
Old Nov 9, 2010 | 04:49 AM
Backwoods18's Avatar
Backwoods18
Check your tranny fluid. Mine was doing the same thing for awhile, then I checked my fluid and it was a little low. Added some ATF-4 and now it's fine
Old Nov 9, 2010 | 06:06 AM
WTEBOY703's Avatar
WTEBOY703
was going to say the exact same thing...when mine was done by VALVOLINE they did not add enough fluid so after 3 days of this hard shifting sound i checked it and it was low...filled it up to where it was full and no probles since then!
Old Nov 9, 2010 | 08:46 AM
sdsdsd's Avatar
sdsdsd
Min did it as well untill the after market spin on filter located inside the trans was removed and replaced it with a factory filter. Now it's as good as new!
Old Nov 10, 2010 | 09:10 AM
there`s a spin on filter inside the transmission???
Old Nov 10, 2010 | 10:56 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Same here... mine only does it occasionally though.
Old Nov 10, 2010 | 11:00 AM
rengnath's Avatar
rengnath
Yup, there are actually 2 filters in the transmission. Its never a bad idea to take the the truck to a well-known transmission shop and have them drop the pan and replace the 2 filters, and change the fluid for you. I also had them do a low-pressure flush on mine as well to exchange the fluid in the trans cooler and torque converter. You do not want any flush performed that claims its a high pressure reverse flush or anything of that nature.
And also, there are a couple of transmission relearns in the downloadable service manual for the problem you are stating. It basically involves you starting the truck and doing a sequence of shifts and that is also another fix to the hard shifting.
Old Nov 10, 2010 | 02:29 PM
babygotdak's Avatar
babygotdak
Can you let me know where these are?
Old Nov 10, 2010 | 02:34 PM
Thats hard to do nowadays. I have nmo idea if there are any reputable transmission shops left.
