Transmission Whine
Old Nov 11, 2010 | 09:56 PM
nola24's Avatar
nola24
Default Transmission Whine
At least I think it's the transmission. When ever I'm in low gear, I hear it, and as it revs higher, the noise eventually goes away. I've heard this could mean I need to check the fluid level, or that something is wrong?
Old Nov 11, 2010 | 10:05 PM
did you.......check the fluid level?
Old Nov 11, 2010 | 10:19 PM
Blown287's Avatar
Blown287
Check your rear differential fluid also. If the fluid gets low it can whine.
Old Nov 11, 2010 | 10:21 PM
nola24's Avatar
nola24
I don't know how to check it. Is it like a dip stick under the hood?
Old Nov 11, 2010 | 10:24 PM
Blown287's Avatar
Blown287
The transmission fluid does have a dipstick under the hood. On your ear diff you will see a seal/plug. Pull it out and see if the fluid is up to the top. If its not, fill it up and look for leaks.
Old Nov 11, 2010 | 10:34 PM
but it only does it in low (1st) gear? So when it shifts to 2nd, the sound goes away?
Old Nov 11, 2010 | 11:22 PM
rengnath's Avatar
rengnath
My first gear whines a bit if I downshift while coming to a stop. It doesnt whine any other time including accelerating or in 2nd gear.
Old Nov 11, 2010 | 11:26 PM
WTEBOY703's Avatar
WTEBOY703
check the fluids...for the trany...start the truck put it in neutral when you check the transmission!
Old Nov 12, 2010 | 02:05 AM
Brian9's Avatar
Brian9
It all depends on how often you drive it. If it sits awhile then your going to get that, it even states it in the owners manual.
Old Nov 12, 2010 | 04:59 AM
Backwoods18's Avatar
Backwoods18
Yes sir.
