bad growl
ok, new issue, truck has been great, just hit 100000 miles and i have a serious growl in the frt, it changes with speed so i am thinking wheel bearings, just did the brakes, new rotors pads. wondering if anyone has had issues or even had theirs swapped out. also only when i turn left does the growl increase in sound, but not to the right, had this noise before the brakes but not as loud
Wheel bearing is a likely culprit. I replaced one at 30,000 mi and the interior noise level drop was suprising. They can be obtrusively loud.
No rebuilding - they are fully sealed self contained hubs. Most shops get the part for around $100 and it's about $300 installed.
I would check to see if anything is stuck in the serpentine belt or if something is rubbing against it. If its a "grinding" sound then its probably wheel bearings.
Trending Topics
RockAuto had them for $97 when I looked, non - ABS.
I was considering DIY but I said fck it and had a real shop do it. With a tie rod end too, it was about $375, parts and labor - cheap $60/hr labor.
There are 3 bolts that basically hold the wheel on. You can look up the procedure from a G3 Dakota service manual.
