Getting auxillary foglights installed...
#21
if you want a custom plate to cover that hole to mount switches in just let me know...
#22
#23
I think on some of the other models it was designed for a key'd airbag switch for being able to put a car seat in the front. ext cab and standard cab models etc etc. didn't they use the same bottom piece on durrango's also??
#24
#26
#27
If you think you might end up in the long adding more swtiches (like I plan to). I was thinking of making a plastic strip (and painting to match the dash) and mounting it in the long vertical gap between the radio bezel and the cluster of gauges (sorry cant think of the term, ya know speedometer, tach, fuel etc.)
#29
#30
My 06 did not come with fog lights. Someone hit me in the front and I had the body shop purt on the painted bumper with the fog lights and I paid them the difference.
If I were to buy the factory switch that has the button for the fog lights and install it where my switch is now, is the wireing already there behind the dash, or would I need to run new wire?
