HO cams, did i get screwd???
Old Dec 6, 2010 | 02:39 PM
rengnath's Avatar
rengnath
I know you need a special wedge tool to do 4.7l cams (according to Nick @ Airram) .... could that have happened when removing them without the proper tool?
Old Dec 6, 2010 | 04:03 PM
Blown287's Avatar
Blown287
Wow, the sprockets are still on the cam, that is odd. I want to see the cam under the sprocket and see how that looks.
The tool airram sells wedges between the timing chain puts pressure on the timing chain tensioner and thats all. You can make them out of wood, I did my 1st couple of swaps with a wood one I made myself.
Old Dec 6, 2010 | 04:07 PM
thunder98110's Avatar
thunder98110
is that going to be an issue???
Old Dec 6, 2010 | 05:08 PM
ruger226's Avatar
ruger226
How much did you pay for them?
Old Dec 6, 2010 | 05:16 PM
Blown287's Avatar
Blown287
Nope, you only see a sprocket still on the cam if the engine is done or sprockets and chains get replaced. Do me a favor, the sprocket is held on by a 15mm bolt. Remove the bolt and inspect the top of the cam shaft. That is what I wanted to look at.
Old Dec 6, 2010 | 05:35 PM
thunder98110
ahh ok, give me a few minitues and ill post some pics.
looks all marked up, and that little metal nub at the tops seen better days.
i could only get one of them off at the moment.
what do you think?
Old Dec 6, 2010 | 06:01 PM
Blown287's Avatar
Blown287
If the other one looks like that, the ends are good to go. Thanks brother. When a timing chain brakes it has the tendency to do some damage i.e. shear that tip off. I don't know the story behind these cams but you can never be too safe.
Old Dec 6, 2010 | 06:02 PM
thunder98110
phew. damn. so what does a bad one look like just so i know what to look for once i get it off?
blown, thank you so much man. you really have no idea how much i appreciate this. i wish i could pay you more, but i cant afford it! lol
Old Dec 6, 2010 | 06:06 PM
Blown287's Avatar
Blown287
No worries man. You just want to ensure the threads the retaining bolt came out of aren't stripped and the tip that fits into the sprocket isn't shared off. Inspect every lobe to ensure they aren't chipped or warped. That is about all you can do visually.
Old Dec 6, 2010 | 07:04 PM
thunder98110
WOW, spoke with the seller right now and he said that they were perfect once he pulled them. he said they were in bubble wrap the whole time. he offered to find me a new side to make up for the damaged one.
i wasnt expecting this.
