DIY Air Intake
Old Dec 14, 2010 | 11:00 PM
  #21
KS Cowboy's Avatar
KS Cowboy
Originally Posted by rengnath
Word of warning for anyone doing a DIY intake; dont use PVC. When PVC heats up, it releases toxic chemicals which is why it is only approved for cold water applications. CPVC or ABS are the only things I would use; and Im not sure if you can get CPVC in 3" applications.
Thanks for the Info. I was about to do that, cause all of the plumbers I talk with say that the black ABS will expand and contract with heat. I might look into CPVC though. Ya might be able to get it at a plumbing supply store.
Old Dec 14, 2010 | 11:07 PM
  #22
rengnath's Avatar
rengnath
Yeah, I read the heat issues with PVC before in another thread and ABS was suggested instead. Never really looked in to ABS. I was running some new lines for an RO/DI unit in my basement and while at the store I noticed that PVC is only approved for cold water, and CPVC is approved for hot or cold. My dad didnt even know the difference. He always ran copper for hot water.
I guess ABS wouldnt be the worst if it expanded and contracted; you just dont want gaps to form where unfiltered air can get in. I wonder how much heat it takes.
Old Jan 2, 2011 | 12:01 AM
  #23
08XDakota's Avatar
08XDakota
I was really really tempted to make the one that keithhud made with the ABS plastic but i ended up ordering the K&N Aircharger yesterday....cant wait to get it installed!
Old Jan 25, 2011 | 02:02 PM
  #24
Zombifyd's Avatar
Zombifyd
This question was asked before and there was no answer. But what is the grommet size for the iat sensor? I was hoping to go right from work and pick one up to install my cai.
Old Jan 25, 2011 | 02:23 PM
  #25
I was running some new lines for an RO/DI unit in my basement and .
what in the h$ll do you ghave a RO/DI unit for? You have a pharmaceutical company in your basement?...lol....I'm currrently qualifying a purified water system for my company....these things aint cheap...tom buy or maintain! sorry for the thread hijack...
Old Jan 25, 2011 | 02:33 PM
  #26
rengnath's Avatar
rengnath
Its for the fish tanks. Reef tanks require the purest water to avoid algae growth. City water here contains 168ppm of total dissolved solids, RO takes it down to 2-1 ppm, and the DI takes it all the way down to 0 ppm.
Old Jan 25, 2011 | 02:52 PM
  #27
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I cant remember right off hand, but just throwing it out there, I think its like 3/8 or 7/16s
Old Jan 25, 2011 | 06:18 PM
  #28
Blu3P0ny's Avatar
Blu3P0ny
lol for my CAI (you can find it, fairly recent post) i just used a piece of rubber hose that matched the size of the sensor pretty tightly. If you look at the sensor, it's got a rubber washer on it as well. I then basically drilled a hole so the rubber hose would have so screw on basically go get in the pipe. I then also siliconed it in place from the outside, and test fit the sensor.
A rubber grommet will work as well.... but I was working with exhaust piping - working on heat sheild for both the filter and the tube now.... wish me luck!
Old Jan 25, 2011 | 07:17 PM
  #29
trevorrawson's Avatar
trevorrawson
Well I just moved and have been without internet so I'm down at a local coffee shop excited to finally be back! I finished my DIY CAI and I'll put up pictures as soon as I get internet at my house again which will hopefully be soon!
Rengnath what size reef tank to you have? I just got a 60 gal set up that I'll hopefully have up and running within the next month. I'll get some pictures of that to show you too. I'd love to see yours.
Old Jan 25, 2011 | 07:27 PM
  #30
WTEBOY703's Avatar
WTEBOY703
you didn't come prepared with pictures? shame on you! lol
