06 Dakota body lift.
on
1 Post
took me 10 hours me to..a lot of beer a pizza and 3 good friends!!!and a lot of fun with front bolt and trim the rad frame!!! WORTHED!!!!!!!!!!!!rough country 199$ for a compete suspension lift is a good idea2.5 front and 1.5 in rear....i would prefer a 2,5 rear block still have the bad looking rake but gas tank sits too low!
I loved the way it turned out, the guy I talked too said would deffinetly work so I tried it, worked out for the best.
Day 4...
Damn Christmas gives me no time to do anything, Im gonna try to install my strut spacer, trim and move front bumper and hopefully be able to drive my damn truck today, theres no room in the front wheelwell atm so I can only turn around 15 degrees haha.
Ill try and finish er up and post the finished picks. (After a good wash.)
on
1 Post
ok
if you need help what size strut spacer are you installing??? and what type(under or over spring).... and what is the spec of your 15'' rim you are using ex:15x8 0 offset would be the perfect fit... give us the spec so we can calculate if you do need wheels spacers and how thick....
i regret my 16'' now that i know 15'' can fit our truck...ALOT CHEEPER!!!for same size!!!!
