05 dakota windshield wiper res. problem need help
Old Jan 16, 2011 | 04:05 PM
lanilx's Avatar
lanilx
Default 05 dakota windshield wiper res. problem need help
I disconected my windshield wiper pump from the resevior due to the fact that it was frozen solid. I thawed out the resevior and now When I try to connect it I cant get a solid seal on the pump. It just leaks from where the pump goes in. I was wondering if there is a washer of some kind that I lost when disconnecting it. Any help would be great thanks in advance
Old Jan 16, 2011 | 04:07 PM
rengnath's Avatar
rengnath
Theres a good chance that when it froze something cracked and now its leaking. Unfortunatly when liquid freezes it expands .... and in this case it probably didnt have anywhere to go.
Old Jan 16, 2011 | 04:10 PM
lanilx's Avatar
lanilx
Yea but it dosent look like it is leaking from a crack it is leaking from where the pump inserts and I am just not getting a tight seal thats why I am asking if there is a washer of sometype that I lost
Old Jan 16, 2011 | 04:20 PM
rengnath's Avatar
rengnath
Heres what I have in the parts manual. You can start searching part numbers online to try and find diagrams of the pump itself.
1 55056383AA 1 HOSE, Coolant Overow
2 55056485AA 1 CAP, Washer Reservoir
3 05161367AA 1 FILTER, Windshield Washer, Under
Cap
4 05161376AA 1 GROMMET, Washer Reservoir
5 05161374AA 1 GROMMET, Washer Level Sensor
6 05161379AA 1 SENSOR, Washer Fluid Level
7 05161378AA 1 PUMP, Windshield Washer, Single
Outlet, Single Outlet
8 05161373AA 1 GROMMET, Windshield Washer
Pump
9 HWV00532AB 1 HOSE 1FT, Windshield Washer,
5/32"
10 55056520AA 1 BOTTLE, Coolant Reserve &
Washer Fluid, Overow
11 55056382AA 1 CAP, Coolant Reserve Tank
-12 04334799 2 CONNECTOR, Washer Hose, In
Line, In line 3/16“
-13 03799520 1 GROMMET, Hose to Reservoir
Old Jan 16, 2011 | 06:46 PM
Eimer123's Avatar
Eimer123
I would say either the line to the truck is still frozen and the pump has no where to push the fluid. Or the hose is still very cold that when you removed it you expanded the size of the tube. I would probably get the wifes blow dryer out and warm up the hose and connection then cut off a half inch of the tube and reconnect it.
Old Jan 16, 2011 | 07:31 PM
lanilx's Avatar
lanilx
piece 8 on the list is a grommet I think that is what I am missing
Old Jan 16, 2011 | 07:48 PM
Blown287's Avatar
Blown287
Without the grommet the pump will not seal. When I pulled out my overflow/washer bottle combo to fit the blower mine came out. When you lift the pump off the tank you can see where the grommet goes.
Old Jan 16, 2011 | 07:50 PM
lanilx's Avatar
lanilx
all right I lost the grommet thats a dealer only item I bet
Old Jan 16, 2011 | 10:02 PM
Blown287's Avatar
Blown287
I bought mine from Ace Hardware. Back in the bolt section there is are automotive specific parts and thats where I got mine.
Old Jan 17, 2011 | 10:21 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I am sure any grommet the same size will work...
