Anyone running 35's ?
Old Jan 30, 2011 | 12:36 AM
  #41
Sdowdle541's Avatar
Sdowdle541
Anybody noticed this dakota on cardomain with 35s?......http://www.cardomain.com/ride/243296...ar-cab-chassis
Old Jan 30, 2011 | 12:44 AM
  #42
Dakkkota's Avatar
Dakkkota
yes the guy's truck is falling appart...and dos not sale anything anymore from what i read
Old Feb 4, 2011 | 01:24 PM
  #43
Desert_Rat's Avatar
Desert_Rat
Originally Posted by Dakkkota
do you plan to level fuel tank??? it should do a BIG difference everytime i got stuck it was the damn tank that was draging (1 inch lower than the truck)
Yes, I looked into it and there is PLEANTY of room. The hardest part/only thing stopping it is a cross member chassis support spanning from the left to the right that is directly over the gas tank. So to move it up, this would need to be cut off, extended, raised with blocks, and rewelded/bolted on. This would also give support back to the bed that was lost due to the 3 inch body lift. I will definitely do it when I get a chance and a friend to help take the bed off.
I also plan on doing full skid plates across the bottom from front to back. Moving the gas tank up will allow the plates to sit higher and remain level across from the left chassis to right.
