LED tailight conversion
Old Feb 1, 2011 | 12:40 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Heeey, I never thought of that, maybe I should order some for the bike... They are just as expensive as HD OEM bulbs (I tried normal, same bulb number, aftermarket ones and I get a blown bulb after a few trips). I dont believe I would need a resistor setup on the bike either. Hmmmmmmm I dont knwo why I didnt think of that before...
Old Feb 1, 2011 | 12:47 PM
Originally Posted by lootownpunx
I just ordered the same set. where did you get your load resistors?
Old Feb 1, 2011 | 01:35 PM
rengnath's Avatar
rengnath
Oh boy, I feel another mod for my truck coming on ....
Old Feb 1, 2011 | 08:01 PM
krazyistkarl's Avatar
krazyistkarl
im really digging you fender flares. and damn im jealous i dont have an 08+
Old Feb 1, 2011 | 09:45 PM
lootownpunx's Avatar
lootownpunx
they work fine on the bike as long as turn signals are not intregated into the brakes.
Old Feb 1, 2011 | 09:46 PM
lootownpunx
http://cgi.ebay.com/ebaymotors/2x-LE...item3364663462
Old Feb 1, 2011 | 09:49 PM
lootownpunx
did some more looking at bulbs these are the same as the red spider ones but white which is better for our red lens...and there a lil cheaper hah
Old Feb 1, 2011 | 09:57 PM
so what do we need...25 watt of 50 watt?? for rear brake/turn lights...
Old Feb 1, 2011 | 10:27 PM
lootownpunx
i have 25s on mine,far as i can tell they work fine
found a detailed writeup on them here
http://www.plasmaled.com/tail_light_led_bulb_fix.htm
Old Feb 1, 2011 | 11:07 PM
FrenicX's Avatar
FrenicX
Got this from www.superbrightleds.com
they have a lot of other info there too.
Plus explanations of which shape works best for each area.
"Which Color LEDs should I use?
For best results the LED color should be the same as the lens color or if bulb is behind a clear lens, use the appropriate color for turn and brake light functions. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens."
