suspension help
rancho shock will stiffen the front for around 125$each
or a tm leveling kit...or both will be VERY STIFF
I just got Ranchos and a TM kit installed today. Nice and stiff ..... the truck handles amazing. Taking turns and braking feels awesome.
I got my Ranchos for $165 shipped from autopartswarehouse with a coupon.
http://www.trailmastersuspension.com/
You may want to look for a 2" kit for 2wd. Your back end to front end rake is a little greater than a 4x4s.
if its because the front end is bouncing it will make it worst besause stock dodge shock are weak... if its not bouncing then go for the TM spacer installled inside the shock..but if you have the opportunity to have the shocks in your hand its the good time to change them monroe with TM or rancho alone
If youre going to install any kit inside the strut, just do new struts. Youre basically all the way there labor wise. And youll want a front end alignment when you get the kit installed, my steering wheel needed to be straightened since the shaft was at a new angle.
Trending Topics
He is correct
Last edited by lghtngblt02; Feb 3, 2011 at 10:16 AM. Reason: Not helping/edited quote
