Sonnax
Old Feb 9, 2011 | 07:19 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Default Sonnax
anybody have a link for a sonnax harness for an 06 4.7?
Old Feb 9, 2011 | 07:34 PM
Eimer123's Avatar
Eimer123
here is the air ram version
http://www.airram.com/product.php?productid=1486
Old Feb 9, 2011 | 07:54 PM
06Dak4.7Silver
thanks man, would you recommend this mod?
Old Feb 9, 2011 | 07:59 PM
Eimer123's Avatar
Eimer123
I have superchips programmer with TM, and they are not compatible with each other. I have heard people like the mod, but I like have more control over every shift with my programmer.
Old Feb 9, 2011 | 08:04 PM
marcsnyder05's Avatar
marcsnyder05
If you don't have a programmer I think they are great. I have a Sonnax and I love it
Old Feb 9, 2011 | 08:38 PM
Amanka's Avatar
Amanka
i have and use both a sonnax and superchips with tm, works great
Old Feb 9, 2011 | 08:47 PM
rengnath's Avatar
rengnath
My conflict with the TM tuning and Sonnax may have been due to a failing trans pressure sensor. The sensor was replaced and the filters were changed and there was no more slipping, so Im not sure if thats why mine would hold in gear. Ill never know .... the SC TM tuning shifts good for me.
Old Feb 9, 2011 | 08:48 PM
Blown287's Avatar
Blown287
Here you go.
https://dodgeforum.com/forum/3rd-gen...s-arrived.html
Old Feb 9, 2011 | 08:50 PM
Amanka's Avatar
Amanka
^ nice pic ^ (rengnath)
ive never had any conflicts using both, the sonnax stiffened up the shifts more than the superchips alone would. i did have to turn up tm so it wouldnt break my neck tho,
Old Feb 9, 2011 | 09:05 PM
rengnath's Avatar
rengnath
Thanks Alex.
Yeah, the Sonnax is actually a "safer" mod than Superchips, but some would argue that increasing pressure isnt always safe. Ill explain quick.
The 545-rfe already shifts firm from the factory, but the reason you cant feel it is due to the torque management. They can yield a safe, soft shift so thats why its that way.
So by decreasing TM, you are technically putting more stress on the transmission because more power is sent from the engine to the drivetrain during the shift. I doubt its anything that will cause any problems, but it is more "stress" on the drivetrain.
Now the Sonnax will reduce more slipping in the transmission during shifts, therefore giving you a safe and firmer shift. However, the pressure lines in the 545rfe are already pretty high, and you are just adding more with the Sonnax. But, people have run both with no problems yet.
