time for me to try different plugs
Old Feb 14, 2011 | 12:55 PM
gjmoran's Avatar
gjmoran
carb cleaner?
Old Feb 14, 2011 | 01:52 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I would use electrical cleaner to play it safe... carb cleaner is a little abrasive on electronics...
Old Feb 14, 2011 | 03:29 PM
gjmoran's Avatar
gjmoran
could i find it at autozone or something similar or have to go to a specialty store?
Old Feb 14, 2011 | 03:36 PM
lghtngblt02
Yeah autozone or any other auto store should carry it...
Old Feb 14, 2011 | 03:46 PM
Eimer123's Avatar
Eimer123
Any hardware store will sell it also. Might even find it are wally mart. I have used carb cleaner on it every oil change and have never had an issue with it.
Old Feb 14, 2011 | 05:05 PM
gjmoran's Avatar
gjmoran
this is from another old thread:
Originally Posted by rengnath
Just remove the throttle body. The results will prove much better, IMHO. Its only 3 bolts, and you will see why after you pull it off. There are small chambers on the back that you simply wont be able to get clean with just spraying. Plus, you wont risk any harm to your engine.
First, disconnect the battery. Remove the intake hat/tube and the connections to the IAT (intake air temp), IACV (idle air control valve), TPS (throttle position sensor), the vacuum line, and throttle control cables. Use an 8mm socket and remove the TB. Use a torx bit to remove the TPS and IACV from the TB. The IACV wont pull out easily. Youll need to try and turn it to get it out, but dont break it. After that, go to work with the throttle body cleaner, q tips and a rag. Spray the TB, but use caution when spraying the cleaner. It doesnt do good on plastic parts, so stay away from the throttle control piece and try to keep it away from the shaft seals that control the butterfly. After the TB is clean, you can also clean the IACV. The TPS shouldnt need cleaning. Use an electronic cleaner to clean the IACV. Throttle body cleaner is way to strong and will ruin it. I would avoid saturating the IACV or trying to rub it down. It is very sensative and you may risk ruining it. I cleaned mine and still had an idle problem, cleaned it again a little to much and ruined it so I needed a new one. So just use caution. A cleaner that isnt too strong and dries fast works best.
I would pick up new gaskets from Napa. Get the mounting seal and the 2 o-rings for the IACV so you will have no problems. Use a little vaseline to create an air tight seal on all the gaskets, and install the sensors on the TB, and the TB back on the engine. Torque the 3 bolts to 9 ft lbs per Autozones repair guide, and connect all the sensors and cables. Reconnect the intake tube and the battery, and you should be good to go. It will take about 60 miles for the PCM to initially relearn the engine parameters, so if it acts a little funny at first give it some time.
what size torx bit will i need?
Old Feb 14, 2011 | 06:35 PM
rengnath's Avatar
rengnath
T25 or T27 I believe.
Old Feb 14, 2011 | 09:21 PM
gjmoran's Avatar
gjmoran
is there any other way to get those sensors out without taking the whole tb off? i tried at lunch today with what little tools i have but i didnt feel like pulling on something too hard and having it break off lol
Old Feb 14, 2011 | 09:42 PM
rengnath's Avatar
rengnath
Yeah, the TPS is very simple to get off with the TB on the truck. The IAC can be done, but its a little tight. My snap on driver didnt exactly fit in there, I had to wedge it in between the wire harnesses and stuff. If you had a slimmer one, or had a ratcheting torx setup, you could definetly do it. I wouldve put it on a ratchet with a 1/4" socket, but I already have dropped a few things in the cracks of the block and had to go fishing.
Old Feb 14, 2011 | 11:27 PM
gjmoran's Avatar
gjmoran
which one is whichlol
