time for me to try different plugs
To remove the cc cable, open the throttle body, twist the cable so the slot if facing downward, and just push. It will slide off.
For the vacuum line, its easiest to take a small flat head screw driver, put it in and twist a little to back the line off a little, and then pull.
Nope, dont remove the nut.
Grab the cable behind the black piece, and open the throttle enough to give you some slack in that cable. Have the cable going straight up from the throttle, and push down on that black piece. It will go, it just takes some effort to push it off. It slides parallel to the cable that is running. You will need to get some slack in the cable to remove it though.
