Scratching my head on an 06 4.7l QC
Mileage seems normal for this time of yr... remember 2-3 starts a day and idling till warm for say 10 mins is almost like driving with the peddle mashed for the same amount of time.
Wheel bearings will usually make noise...
I knew mine was bad because I could hear it growling in the front right wheel. I had a Grand Am that made the same noise, and those were notorious for destroying Hub bearings every 10k.
That's what mine normally does, drops 2-3mpg with the winter blend. Now its dropped 5-7 mpg. I don't have the overhead computer either, so its all done by paper.
x2 on spring getting here soon too.
There is that drop in power you were talking about at highway speeds. How does your fuel pump sound? Are the fuel filters easy to change on the daks? My last truck has this highway speed issue and I solved it with a new filter and eventually a new pump.
If you lose a bit of speed you may find yourself pushing the pedal to get back up. Feathering the throttle so to speak. That will kill gas mileage.
Hope you figure it out before your move because that will change you driving characteristics more than anything.
I will still drive some eway miles, as I have to use this truck for work, driving 20-100 miles a day. I will just lose the consistent 30 miles back and forth every day.
