Fog Lights in ST bumper
Old Feb 14, 2011 | 09:10 PM
The Dutch Touch's Avatar
The Dutch Touch
Default Fog Lights in ST bumper
Hey I was just wondering if anyone with an st bumper without fog light holes ever put in fog lights in by either cutting out the hole or buying a bumper with holes, and if so how did the installation go?
If I were to do this I would prabably buy this kit, would this be enough?
http://cgi.ebay.ca/2005-2009-DODGE-D...item4cf50b7437
Old Feb 14, 2011 | 09:11 PM
didnt cheeseburger do that?
Old Feb 14, 2011 | 09:15 PM
rengnath's Avatar
rengnath
Yes, yes he did. I cant remember where he mentioned it though. He said it was a b!tch ....
Old Feb 15, 2011 | 04:55 AM
Backwoods18's Avatar
Backwoods18
He had a hard time finding the wiring for them I believe..
Old Feb 15, 2011 | 10:00 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Here's the issue with installing factory fog lamps on our ST trucks (and why I haven't done it yet). The kit from the dealer runs around $150 the last time I checked. It comes with the factory rotory switch, that when depressed, activates the fog lamps. It also comes with the lamps, wiring harness, and bezels. You basically have to remove the ST bumper, cut the holes, slide the bezels in, and then bolt the lamps up. After that, install the wiring harness and new switch. Should be fine right? No. Now you have to go to the dealer and have them Starscan the the motherf%^&er so that they activate.
I'm half way tempted to get the bezels and lamps, and make my own wiring harness so that any time the parking lights are on, so are the fogs. Getting this aftermarket ebay kit might be good if you want to do it this way. However, you will have to get the bezels from Dodge if you want it to look good.
Old Feb 15, 2011 | 10:28 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
A simple power, ground and relay setup will do wonders. I had a setup like this on my old dak.. when the parking lights were on they would switch on regardless of headlights being on. You could get real complex and have it setup so that when you high highbeams on they would be off...
Old Feb 15, 2011 | 10:30 AM
You could also get the housings from rock auto and wire them up as donkey mentions. The factory housings are @$13.
Old Feb 15, 2011 | 11:19 AM
rengnath's Avatar
rengnath
I think another problem was getting the holes cut through the bumper since they are currently closed up with vents.
