someone with 4wd to provice pics and dimensions
Old 03-16-2011, 05:47 PM
projektdirtfab's Avatar
projektdirtfab
projektdirtfab is offline
Default someone with 4wd to provice pics and dimensions
hey guys. just wandering if someone with 4x has a junk or spare cv axle laying around or is willing to take theirs apart real quick and make some measurements and take some pics.
  • spline count
  • any mounting bolts used, and what MM they are and how many there are
  • how tall the joint is if you lay it flat on the ground (width?)
  • how tall it is if you stand it up (like it is on the truck)
  • anything else you can think of i guess lol
  • lots of pics too!!
Thanks!!!
Old 03-16-2011, 07:27 PM
rengnath's Avatar
rengnath
rengnath is offline
I threw away my old CV when I replaced it ..... there was no core charge. I wouldve sent it to you.
Old 03-16-2011, 07:47 PM
projektdirtfab
lol....yea that doesnt really help
Old 03-16-2011, 09:29 PM
donkeypunch's Avatar
donkeypunch
donkeypunch is offline
King Jackass
Let me see what I can muster up.
Old 03-16-2011, 09:57 PM
projektdirtfab
sweet. i appreciate it...actually the 4x4 guys appreciate it. heres some measurements to take if you can get the INSIDE CV apart from the axle. i dont need to know about the outside cv joint. just the inner.
if you have a digital mic. we need to see how close the measurements on the 4x4 dakota cvs are to the 930 cvs....(should be the same)
this should equal 108mm...
this should be close to 40mm
and of course a verification for the number of splines....iirc 930 joints are 28 splined with the above width and height measurements. so if you guys have 33 spline or 35 spline with bigger measurements than well have to inclue 934 joints instead of 930
Old 03-16-2011, 10:16 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
do you have pics of this how the fits in the cv under the boot???
Old 03-16-2011, 10:47 PM
hendrixx324's Avatar
hendrixx324
hendrixx324 is offline
Im pretty sure i have an old cv shaft layin around
Old 03-17-2011, 02:31 AM
projektdirtfab
cv shaft? or cv joint? or are you referring to cv shaft as an assembly?
Old 03-17-2011, 02:33 AM
projektdirtfab
like this:
i mean theres nothing to it....
Old 03-17-2011, 01:00 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
good picture now i understand!!
Quick Reply: someone with 4wd to provice pics and dimensions
