Engine surging issue
Old Mar 20, 2011 | 06:45 PM
05Dakota93's Avatar
05Dakota93
Default Engine surging issue
Hey all,
My 2005 dak with the 4.7 (60k miles) has been having idling and surging issues. This problem was happening before a few months ago but seemed to cure itself and didn't happen again for quite awhile until now. When the truck is put in reverse to drive quickly or vice versa, the engine dips below 500rpm and nearly stalls. The engine also surges up and down between 300 rpm and 1500 rpm at redlights or Immediately after the truck is put in park. Any suggestions? I was thinking tps, maf, or iac valve. The problem is much worse when the AC is on.
Thank you everyone
Old Mar 20, 2011 | 07:23 PM
I would start with the IAC. Take it out and clean it real good. Also not a bad idea to just remove the whole throttle body and clean the bore real good. Not that hard to clean and a heck of a lot easier to do off the truck than on. Only 3 torx head screws hold it on, remove the IAC, TPS electrical connectors, a vacuum hose and 2 cables (throttle and cruise control) and your done.
Old Mar 20, 2011 | 08:05 PM
Hammond_Egger's Avatar
Hammond_Egger
Ditto on what jkeaton said..I had the same issue, cleaning the IAC fixed the problem.
There is usually a bunch of carbon on the plunger on the IAC, and cleaning the whole TB is a good idea as well. Grab an old toothbruch and some TB cleaner..
Let us know how you make out!
Old Mar 20, 2011 | 08:22 PM
05Dakota93's Avatar
05Dakota93
Will do, Thank you! I appreciate the help.
Old Mar 20, 2011 | 08:52 PM
05Dakota93's Avatar
05Dakota93
Update:
Check engine light just came on. Hoping the cleaning will help
Old Mar 20, 2011 | 09:08 PM
Do you have a reader?
Old Mar 20, 2011 | 09:11 PM
Is say the code a probably going to be idle related since it can't control it
Old Mar 21, 2011 | 12:52 AM
Blown287's Avatar
Blown287
That is your EGR valve man. It's hard to get to but I can almost guarantee that is your problem. That big of surge after coming out of throttle has to be the EGR. It's behind the manifold on the driver side. If you look at the metal tube coming out of the intake manifold, it goes right to it.
Old Mar 21, 2011 | 04:27 AM
Backwoods18's Avatar
Backwoods18
I am thinking EGR as well..
Old Mar 21, 2011 | 12:11 PM
sdsdsd's Avatar
sdsdsd
IAC Cleaning cured mine, same issues!
