Leveling kit question
Old Mar 24, 2011 | 11:33 AM
MitsuRaider's Avatar
MitsuRaider
Default Leveling kit question
Hey guys, so im looking to get some lift on my truck.
The forum recommends that I keep it within a 1.5" to 2" lift.
So i found the following kit on Ebay.
http://cgi.ebay.com/ebaymotors/2-Fro...Q5fAccessories
However, those are only the front spacers so i would need to buy the rear blocks separately.
Anyways my question is, how big should the rear blocks be if I want to keep the truck leveled?
Thanks!
Old Mar 24, 2011 | 11:38 AM
dakota_raven's Avatar
dakota_raven
That's the only thing you need. If you put blocks on the back it will go on to have the rake like the factory look.
It will be leveled with those spacers.... Good Luck!!!
Old Mar 24, 2011 | 01:17 PM
MitsuRaider
So a 2" spacer in the front takes care of the slope. What if I want to give the truck a slight lift for bigger tires? How big should the front spacer be and the rear blocks?
Old Mar 24, 2011 | 01:31 PM
Rusty513's Avatar
Rusty513
I just had mine put in yesterday. 2.5" spacers up front & 1.5" blocks in the rear.
Old Mar 24, 2011 | 01:33 PM
Here's a kit that Rusty513 just installed on his 4x4. Good price, too. I believe, suspension wise, there is no difference between a Raider and a Dakota??
http://totalperformanceonline.com/ez...30/100-213-15L
Old Mar 24, 2011 | 02:39 PM
rengnath's Avatar
rengnath
2.5" will technically make the truck sit level. With my 1.5", I have a 1 inch difference on flat ground between the front and rear wheel well height.
That being said, unless you want to keep the rake, I wouldnt lift the rear. Any tire that you can fit in the front, will fit in the rear with no modification as far as I know. Guys normally have to start trimming the front with 265/75/16s and a 1.5" leveling kit if I recall.
Old Mar 24, 2011 | 02:59 PM
MitsuRaider
Thanks guys, that was great.
My first step will be buying the 2.5" spacers in the front.
The 2.5" should level the truck, and i will see if I need any additional height increase once i look up some bigger tires.
Old Mar 24, 2011 | 03:28 PM
rengnath's Avatar
rengnath
Are you 4x4 or 2x4?
Old Mar 24, 2011 | 04:05 PM
MitsuRaider
Originally Posted by rengnath
Are you 4x4 or 2x4?
My truck is a 2x4
Old Mar 24, 2011 | 04:08 PM
rengnath's Avatar
rengnath
You should have no problems then with a 2.5" then. With a 4x4, it could cause some problems eventually.
Sorry about my comment before, a 2.5" would make a 4x4 perfectly level. Your 2x4 might need a little more, but it should be close. Im not sure how much lower the fronts sit on the 2x4 models.
