what else could go wrong???
Old Apr 4, 2011 | 10:35 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Ooops...
Old Apr 4, 2011 | 07:13 PM
Eimer123's Avatar
Eimer123
Cam swap gone wrong?
Old Apr 4, 2011 | 08:51 PM
hendrixx324's Avatar
hendrixx324
yess.... it just keeps getting better
Old Apr 5, 2011 | 12:47 AM
Blown287's Avatar
Blown287
Sean reset timing like we discussed, looks like the left bank was off off my around 30 degrees. That is enough to get piston/valve smack. I think he's pulling the head tomorrow. I just wish he was closer so I could help him out.
This does confirm one fear I did have. The 4.7L is supposed to be an interfernece motor, so a tooth out of time should keep it from starting. On Travis's, it didn't. A tooth off still allowed him to start it and didn't even throw a code. Sean is the 2nd person I've known to have a 4.7L 30 degrees out of time and still start. The other was an 2000 4.7L with JTEC PCM, now I see it's possible even for the newer NGC as well.
Old Apr 5, 2011 | 08:26 AM
donkeypunch's Avatar
donkeypunch
King Jackass
If you did have piston to valve contact, pm me. I'm a dealer through SI valves and I can give you a hell of a deal on some high performance valves.
Old Apr 5, 2011 | 03:48 PM
gjmoran's Avatar
gjmoran
would being 1 tooth out of time cause a rough idle?
Old Apr 5, 2011 | 06:06 PM
gjmoran's Avatar
gjmoran
is it possible to just have the idling issues and not the driveability issues?
Old Apr 5, 2011 | 08:12 PM
Dakkkota's Avatar
Dakkkota
on my ATV its a common modification people rotate one cam one tooth to gain HP would that be possible on our truck???
