HHR fan arrived!!!
Old Apr 13, 2011 | 04:18 PM
Dakkkota's Avatar
Dakkkota
just ordered the derale for 30$
Old Apr 13, 2011 | 04:49 PM
Cuban11182's Avatar
Cuban11182
Can I ask where you got it for $30?
Old Apr 13, 2011 | 05:04 PM
Dakkkota's Avatar
Dakkkota
Friend speed shop owner at cost price +2$
Old Apr 13, 2011 | 05:15 PM
Cuban11182's Avatar
Cuban11182
not bad!!
Old Apr 14, 2011 | 04:24 PM
Dakkkota's Avatar
Dakkkota
oops 56,91tx in...
30$ was the flex-a-lite without the sensor
Old Apr 14, 2011 | 04:58 PM
Cuban11182's Avatar
Cuban11182
I was thinking DAMN that's a good price!! I think you have convince me to get the fan and the Hayden to try mine again. The Taurus fan I had I think was jacked up and drew too many amps.
But that will have to wait till next month. I'm waiting to my throttle body to ship (hopefully tomorrow) and I'm waiting to hear back from Hemifever about an SCT for my Raider.
Old Apr 14, 2011 | 05:11 PM
Dakkkota's Avatar
Dakkkota
i will compare the mileage per gallon with stock thermostat with the e fan compare with 180 thermostat later
Old Apr 15, 2011 | 12:29 AM
Ueland's Avatar
Ueland
Just a note on my complete write up in the other post, I decided to change which fuse I hooked up the trigger wire to in the fuse box. I instead chose to use the "heated seat" fuse as I found that when the key is in the "run" position the fuse is live, and when its in the "accessory" position, the fuse is off. Main reason for this was when I turned the key backwards to the "acc" position to listen to the radio, the fan would still actuate even though the truck wasn't running. It wasn't doing any damage or running down my battery, It was just annoying to have it running while I had the engine off and the radio on.
Old Apr 15, 2011 | 11:02 AM
Dakkkota's Avatar
Dakkkota
thank you!
Old Apr 19, 2011 | 04:32 PM
Dakkkota's Avatar
Dakkkota
how do you hook the wire in the box??
