HHR fan arrived!!!
Old Apr 19, 2011 | 07:47 PM
  #21
Dakkkota's Avatar
Dakkkota
Originally Posted by Dakkkota
how do you hook the wire in the box??
i did it temporary (twins the wire around fuse and relay pin)
how do i ajust the deral???
Old Apr 20, 2011 | 10:56 PM
  #22
Ueland's Avatar
Ueland
hopefully your read the instructions.. but to adjust it you just turn the little adjustment screw in the front of it.
my way was to get a cold truck, then turn the ignition on (not the engine) then adjust it till it turned on. once I did that I backed it off a bit just so I knew whch way to turn it etc etc... Then I started the engine.. kept checking the temp gauge till it sat where it used to and adjusted the screw so the fan was on at that point. I then shut the truck down let it cool a few degrees and made sure i had it set where I wanted it. double checked it for about a week but was happy with my initial set point.
Old Apr 21, 2011 | 02:02 PM
  #23
Dakkkota's Avatar
Dakkkota
post pix on how you pick the wires in the fuse box pls!!! i did it temporary still dont know how to do it right
Old Apr 21, 2011 | 08:55 PM
  #24
Ueland's Avatar
Ueland
Here.. just posted about it..
https://dodgeforum.com/forum/2486084-post37.html
Here's the whole thread...
https://dodgeforum.com/forum/3rd-gen...ml#post2486084
