Need help with diagnosis
Old Apr 22, 2011 | 05:15 AM
Backwoods18's Avatar
Backwoods18
Default Need help with diagnosis
I was driving to work yesterday and as I got around 40-45 mph. The truck started shaking bad, almost felt like a warped axle lol. As it was shaking it started to squeal loudly and pull to the left. I had the steering at 3 o'clock to keep it going straight. I pulled over and check the lug nuts, they were tight. I am thinking I have a seized caliper, which warped my rotor. Here's the kicker though, I get in my truck and drive home, all is well. Still shakes ever so slightly, doesn't pull. I can tell my rotor(s) are warped now pedal pulsates, plus that god awful squeal. Any ideas?
Old Apr 22, 2011 | 05:29 AM
Bigboytoys's Avatar
Bigboytoys
I think you hit the nail on the head with you self diagnosis...The reason all was better once you jumped back in, is that the caliper had enough time to cool down and release itself.
Old Apr 22, 2011 | 07:45 AM
Eimer123's Avatar
Eimer123
I agree, sounds like a caliper, or you threw a wheel weight, or both
Old Apr 22, 2011 | 07:58 AM
yep, sounds like you got it right, or a wheel bearing....jack it up and see if you have any play in the wheel.
Old Apr 22, 2011 | 05:35 PM
hendrixx324's Avatar
hendrixx324
yea id say seized caliper... throwing a wheel weight wouldnt shake like that lol.
Old Apr 22, 2011 | 06:45 PM
Backwoods18
Originally Posted by ericemery
that rotor would be freaking HOT if the caliper locked up and had enough contact to warp that sucker. Did you smell brakes when you got out?
It did it again on the way home from work tonight. Still don't smell brakes nor is either rotor abnormally hot. It has a small vibration when going 55 and when the brakes are applied it rattles the teeth out of my head. Wheel bearing or seized caliper? Thanks again for all the help guys!!
Old Apr 22, 2011 | 11:31 PM
when you find out let me know, may be the answer to my mystery vibration (though mine is not brake related)...
Old Apr 23, 2011 | 12:09 AM
hendrixx324
the rotor could be warped still
Old Apr 23, 2011 | 05:23 AM
Backwoods18
Ok When as soon as I get a chance after work I am jacking it up pulling the wheels and removing the wheels and then I am taking off my caliepr's and turning my wheels. If they turn completely free then it is the calipers, if not then it is a hub. I will keep you guys updated
