Who on this forum can do metal fabrication or fiberglass?
#21
Guest
Posts: n/a
I will get some shots for you... I have been kind of busy moving into the new house, and trying to get the little league team going. I just need a nice day where I am not loaded down with stuff to do.
I drilled 4 holes in the corners, and used stainless machine screws with washers to hold it on. I also used 3m panel adhesive between the scoop and hood.
#22
No problem. I could try to to make a scoop. I will need pictures and measurements of the R/T to make it as close as possible. I will see what I can do..
#23
