Cant get leveling kit installed
Old 07-05-2011, 08:45 PM
Dakkkota's Avatar
Dakkkota
Dakkkota is offline
Old 07-05-2011, 09:36 PM
jkeaton is offline
Dodge Forum Administrator
i think where they went wrong today was putting the top in first. they never got to the point of trying to get the ball joints back into the spindle.
Old 07-05-2011, 09:40 PM
Eimer123's Avatar
Eimer123
Eimer123 is offline
I started with the bottom control arm and then forced the top into the pocket, but mine was a inside the coil version.
Old 07-05-2011, 09:47 PM
jkeaton is offline
I'll give it a go this weekend. I at least know I will be able to get the bottom bolt out. and I will make a "how-to".
Old 07-06-2011, 01:22 AM
cheeseburger's Avatar
cheeseburger
cheeseburger is offline
I am pretty sure i put the bottom in first.
Old 07-10-2011, 07:01 PM
Maxtork's Avatar
Maxtork
Maxtork is offline
Well I finally got mine installed. I had to adjust the camber bolts to get both the top and bottom of the strut assembly bolted in. Then I borrowed a length of chain with hooks on the end. I hooked one end to the floor jack then ran it up over the spring perch andback down to the jack again. Now when I jacked the lower control arm up it wouldn't just lift the truck...it would collapse the strut enough that I could get the upper ball joint reconnected. Once i got the process figured out it went really smooth. Sorry I didn't get any pictures but if you have any questions on how I did it just ask and I will try to help.
Max
Quick Reply: Cant get leveling kit installed
