Lifter noise
Old Jun 3, 2011 | 06:50 PM
phil74501's Avatar
phil74501
Default Lifter noise
Just got the truck back from the shop, again. The waterpump needed to be replaced. The mechanic told me he thought he heard some lifter noise. He said to go to an auto parts store and get something to stop it. He mentioned something by Lucas. I've forgotten what he said specifically. What can I put in to, hopefully, stop the noise. Thanks
Old Jun 3, 2011 | 07:12 PM
hendrixx324's Avatar
hendrixx324
well is it very loud? because lifter noise is a normal thing four our engines they all do it.
Old Jun 3, 2011 | 07:42 PM
phil74501's Avatar
phil74501
Yes. It wasn't making that noise a few weeks ago. It sounds like it's coming from the right side of the engine. I thought it was because it was misfiring. Got that stopped and it's still doing it.
Old Jun 3, 2011 | 07:45 PM
hendrixx324
why was it miss firing?
Old Jun 3, 2011 | 07:50 PM
phil74501's Avatar
phil74501
Needed new plugs and cleaned the fuel injectors.
Old Jun 3, 2011 | 07:53 PM
hendrixx324
ohh ok and did he say lucus oil stabilizer?
Old Jun 3, 2011 | 07:59 PM
phil74501's Avatar
phil74501
That's what I don't remember. He said he thought he heard some lifter noise. I asked him if that was something that I needed to get fixed fairly soon. He said to just go to an auto parts store and get some Lucas something or other and put that in.
Old Jun 3, 2011 | 08:16 PM
rengnath's Avatar
rengnath
I would use seafoam and pour it down the brake booster and that should clean the top end of the engine.
Old Jun 3, 2011 | 09:03 PM
wingman_214's Avatar
wingman_214
That will help clean the inside of the intake, the runners into the cylinder head, valves and combustion chambers and do nothing for lifter tap.
What viscosity oil do you use? Our engines need 5-20 or 5-30 to run properly. Too thick of oil wil cause lifter tap because its slower to circulate.
I do not recomend lucas oil stabilizer, its too thick.
Get some rislone or marvel mystery oil.
Last edited by wingman_214; Jun 3, 2011 at 09:06 PM. Reason: i spell like forest gump.
Old Jun 3, 2011 | 09:44 PM
phil74501's Avatar
phil74501
I was using 10-30 but switched to 5-30. It was after that oil change that it started. I've been thinking that maybe that has something to do with it.
