is it possible.........
Old Jul 24, 2011 | 05:19 PM
  #21
Reject's Avatar
Reject
Originally Posted by cheeseburger
save yourself trouble and leave the passenger seat airbag sensor attached or u will be paying to have it reset. my airbag light has been on for 6 months now.
Disconnect the battery, let the system drain then unplug and plug it back in when done. The system will most likely never realize it was disconnected.
And the seats, if they are the same as the 2k ones, the center seat is bolted with 4 bolts to brackets. the BRACKETS are riveted to the Driver and Passenger seats.
I pulled the seats out of my old 2k tons of times, By myself (the full seats together) but 2 people makes it ALOT easier, and on Club Cabs, the rear doors would also make it 100x Easier to get them out the doors to.
Old Jul 24, 2011 | 05:23 PM
  #22
dakotaff's Avatar
dakotaff
What is the best/easiest way to remove rivets, drill it out? Anybody have an easier method?
Old Jul 25, 2011 | 06:51 PM
  #23
gjmoran's Avatar
gjmoran
i am interested in this as well
Old Jul 25, 2011 | 07:49 PM
  #24
Reject's Avatar
Reject
Drilling is probably the least destructive, imo.
You could cut the head off with a dremel, or maybe a grinder.
I never removed them off the 2k, I was going to use them to help hold the Console I was going to build.
Old Jul 25, 2011 | 08:17 PM
  #25
Six_Shooter's Avatar
Six_Shooter
As long as the ignition isn't turned on while the air bag is disconnected, the light shouldn't come. We don't have these problems at work, and yes we remove air bag equipped seats frequently.
The best way to remove rivets (that are tight) is by drilling them out with the same size drill that matches the hole they are in. This might take a couple tries to figure out, but even if it's undersized just a little, the rivet will be weakened enough to break free.
Old Jul 26, 2011 | 12:16 PM
  #26
01KotaQuad's Avatar
01KotaQuad
Any progress on this removal?
Old Jul 26, 2011 | 05:21 PM
  #27
gjmoran's Avatar
gjmoran
im in arizona right now ill be back friday night
Old Jul 27, 2011 | 01:09 PM
  #28
01KotaQuad's Avatar
01KotaQuad
Ah ok cool. I'm still caught trying to get this damn suede too...if anything (slightly cheaper) would u consider wrapping the side trim in the toupe vinyl too? Or I could do a different color vinyl like an accent to it....just another option...that place is wanting me to pay the $40 price but I'm still gonna bug him to cut that price and look some other places too
Old Aug 8, 2011 | 04:03 PM
  #29
EliteTempleton's Avatar
EliteTempleton
I like using a punch and a hammer.
But I'm typically not worried about putting whatever I'm de-riveting back together.
Old Nov 29, 2011 | 08:03 PM
  #30
dakotaff's Avatar
dakotaff
Just wanted to follow up and show you what to expect when removing the front middle seat.
Thread ----> https://dodgeforum.com/forum/3rd-gen...sole-swap.html
