Passenger Airbag Sensor issue (after front console swap)
Problem with my passenger airbag sensor after I put my front seats back in. The battery was disconnected and all 3 fuses pulled while the seats were out. Airbag lights, both on instrument cluster and over radio bezel, light up when passenger seat is empty. When someone is sitting in the seat, all lights go out, even if I press on the passenger seat the lights go out. Come back on after about a minute when the seat is empty. I know a few members in the past have had this issue.
I'm going to mess around with the wiring and plug too see if I can correct it somehow. Worst comes to worst, I'll go to the dealer and have the sensor recalibrated, hopefully covered under warranty. Any other input would be appreciated.
The good news is the front console swap is complete, love the storage in this thing.
Early on my truck had an issue with the light going on and off when I hit bumps. It was throwing codes that would not clear.
The issue was the seat sensor is just a bent cable that when weight is on the seat it recognizes that someone is there. All you need to do is adjust the sensor cable.
Trending Topics
The console is from a 2nd Gen Dakota. I picked it up on Ebay, it was taken out of the truck when it was brand new, probably a fleet vehicle that put some custom box in the middle. All of the bolts were in a plastic bag. So I got a brand new console with power outlet for $100. I had previously bid for one on Ebay which went for $200, which I obviously didn't get.
The Good:
The Bad:
The Good:
- All of the mounting holes are already in our trucks.
- The center seat can be removed by 4 screws.
- The wiring for the power outlet is already in our trucks.
- The plugs between the console and the floor are different. There were only 2 wires in both, power & ground. Just grab a 2 wire plug from any auto store and splice them together) I used this one:
The Bad:
- The holes and wiring are under the carpeting, you only need to figure out where to cut the carpet to expose the mounting holes and wiring. The wiring is under a lump and real easy to find, the mounting holes are easy too, just measure on the console. You can kinda feel where the holes are through the carpet. You will not actually feel the hole, there is rubber covering the hole, I guess to prevent water from splashing up.
- Once the center seat is removed, there are 2 brackets on each seat that need to be removed, as they extend into the middle area.
- The passenger seat brackets are held on by rivets (studs), well kinda rivets, they are flat metal with no hole or indentations. You have to center punch in a starting point so you can drill out the metal studs. Start with a small bit and slowly go larger until it pops or you can snap it or chisel it off. There are 4 of these to drill out.
- The Drivers seat is really stupid. The floor mounts on the seat and the bracket that extends to attach the center seat is one solid piece. You have to cut the brackets off, I used a reciprocating saw and it cut through like butter. It may be easier to cut the passenger seat brackets off also, I wish I would have done it that way.
- And of course my Air bag sensor issue, but I'm sure I'll work that out soon enough.
THanks Man, that was extremely helpful.
You have the best color option =D
bad *** leather seat covers
and now a bad *** center console!!
definitely one of my favorite dakotas in DF!
Guys, I found one on ebay right now for about $200 bucks shipped
Im kinda cught up on another project right now but as soon as I'm done I am definitely doing this mod.
Here is the pic of the one I found on Ebay so the rest of you can see how it looks.
