I checked the drive shaft and U joints they all tight and no play, also can not find any grease fittings.
little update... I also feel the TUG before I make a Complete stop....
Thanks...
There wont be any grease fittings anywhere onj the truck unless someone replaced the stock with and aftermarket setup. YES, I know its dumb...
Originally Posted by durapu
rear drum or disk .. I had a 99dakota that I had to replace the rear wheel cylinders - they would stick, check your trans fluid level too .. I'd also look over all the mounts since you are going to be crawling around under the truck anyway .. it is about 7yrs old.
I would suspect a caliper sticking. When you let off the brake it doesn't let go right away. I can't remember if it was Altair that had a couple stick on him, but it has happened before. Which side is it tugging towards?
i have this very same thing happening to me it started when i got the truck not bad at first but now its a hard CLUNK! every time i drive off from a stop light or stop. when i checked under the truck it looked to have had the pinon bearing seal leaking and covering everything around it in oil and i was low in the diff not much, so i guess that the bearing is going bad or is bad? thats the sound i heir?
