Front Brake Pad Replacement
Old Nov 21, 2011 | 04:00 PM
  #21
Originally Posted by donkeypunch
Correct. Is it safe to assume that you are at least turning the rotors? Or are you replacing the rotors?
This is going to be a touchy subject and I'm sure generate many comments. I personally do not turn or replace the rotors until there is a need. I just replace the pads. Never had an issue doing that. If I see a rotor is severely worn (ridged) or feel it warped, then I just replace it. With the tight tolerances these days most places won't turn them because then they would be out of spec. (I was told that on 2 occasions at 2 different places). Not saying anyone is right or wrong, I'm just stating my own experience.
Old Nov 21, 2011 | 08:28 PM
  #22
JimBio's Avatar
JimBio
Agree, I have replaced pads many times without turning them and no issues.
